boost controller
what electronic boost controller easiest to install and to adjust on a 300zx, and if possible not too expensive! similar for a turbo timer!
Profec B simple answer :D paired up with the Greddy FAT turbo timer :)
You've got the
Greddy Profec
Apexi AVC-R
Blitz SBC-iD (dual solenoid best)
They're the popular ones, and they're all complicated, because they're all boost controllers, no getting away from it!
Turbo timer, probably best to buy the option for your immobiliser.
would a turbo timer work ok if i have an immobiliser
From my experience, you can only immobilise the car once the turbo timer has switched off the engine.
Hence my suggestion to have the turbo timer option for your immob fitted... otherwise you've got two systems fighting for control of ignition!
Well no not really cos the turbo timer makes the car think they key is still in the on position by holding the voltage at the barrel ;) The alarm takes its readings from the barrel so as far as its concerned, the key is still in the on position....
