Shall I install my AVCR now or shall I install it after the engine is run in. Doing it later will make the det sensor work which important when running in, I think.
Plus it could remove temptation of turning the boost up.
or shall I stop being soft and install it?
Fit it now!!!
Fit it now? There is nothing for it to control yet ;)
Stu,
Jeff fitted mine for me recently and I love it, great fun plaing around with the boost although I have detonation problems at the levels some guys are running with the same mods on here.
Time to fill with Optimax I think, if this doesnt work then larger injectors are on their way and intercoolers.......god help me....
Worst case Stu, you can set Setting A to low boost 8psi say and run your car at that for a while....then turn to setting B and run loads boost.....:D
I reckon if it's there you'll play with it - leave it out until you've run it in properly!
Also hard to set up properly without a few wide open runs - which you won't be able to do...
Just thought, you could get all the bits through firewall etc whilst you've got access, just don't plumb it in until later?
VGA :bow:
VGA :bow:
Erm... 1152x864! 1024x768!
Very Good... A... :confused:
But ta anyway. :D
VGA is 640x480
SVGA is 800x600
XVGA is 1024x768
who cares over that ;)
