Soft Bov
I bought 2 Turbo XS Bovs off someone on this forum, and all seemed ok. Now zed is stalling when I slowed down, so under recommendation I refitted the original recircs and cured the problem :)
However, I want them back on
After opening them up they have a spring and 6 washers in each, but one is a lot stiffer than the other, and one spring is longer!!
Does anyone either know where I can get replacement springs from OR shall I just put more washers in the loose one (shorter spring?) to try and get the same tension on both BOVs.
Im just a little worried which one should feel right as I dont want to make them both stiff then the BOVS dont open.
No posts to show
