Brake Help Needed Asap Please!!
Hi all ive just been out to change my discs from left tp right due to them being fitted round the wrong way as there grooved
as i dident remove the pads first it was a wiggle to get them off,and as i got the calliper back on,i may of damaged the metal hose coming from calliper
as its leaking from the nut quite alot :eek: and then stopped.is this curable as my fluid levels are the same but dreading going out for a drive what should i do,or will i be ok! :confused:
cheers guys
There is no right or wrong way with the grooves on a disc. Facing one way will give slightly better braking but your pads wont last as long and the other makes them last longer but slightly less performance.
If there was fluid leaking out but the level is the same, there is air inside the lines, which means you press the brake pedal and NOTHING will happen.
You may need to get a new hose, I would suggest getting some brades ones.
cheers srrae broken metal hose my friends making me up some new ones job done perished pipe so need bleeding also thanks all the same!
no z no 4 3 days :( greg
