Help Autobox !!!!!!
ive just been to pick my car up from my garage from having after market gages fitted and when i started it up the auto box was making lots of noise when you rev the car ? its never done this before !!
when i went up the road and stoped at a set of lights all my gears went and would not move ???
i found if you swicth of the engine off the box works again and the gears come back to life.
i got it back to the garage and checked it all over and we are at a loss :cry:
checked and put some more oil in thats ok thers a rattle and a whine and it stops if you turn engine off and back on again but after 2 mins its back and the gears stop working????
help please.
any ideas
  • Replies 27
  • Views 987
could the tps do this?
it was all the problems i had with my two rebuilds
sorry to hear this mate
steve
there is loads on here about tps
i wouldnt mess with it until you get
better advise from someone who knows alot more than me
(its a little black box on the n/s of the throttle boddies)
all the best
steve
dont no but it does mate
it has to be set spot on
steve
Id be VERY tempted to take the car back to the garage that did the work! If it was ok wen you drove it there it must be something they did when fitting ya dials. they might have disturbed a connection or summit?
its back at the garage as its my mates place how did the work but we are just stumped on what it could be
work done today was oil filter and new oil and 3 after market gauges temp,boost,oil pres, and thats it
any more ideas what it could be so we can try and get it sorted billing coming very soon :cry:
This is nothing to do with the TPS. Been through it too. Its the classic expiring zed auto box symptoms. Mine also had occassional vibrations in top gear the month or two before it went and the lock up on OD top stopped working.
I think when whatever it is that goes wrong breaks up inside the box the bits clog the oil filter of the transmission and starve the pressure. Mines did it going slow at 30 mph. Same symtoms turn it off and leave it a mo and drive comes back.
Fraid your prolly facing a re build or 2nd hand box. Especially if the box oil is now smelly and leave a brown stain on the rag.
ive never had any sign of the box on its way out at all,
so many people have said how quite the engine is
drove it to the garage this morning and fine, went to pick it up took of the ramps and started it up and this noise was there ???
i dont want to buy a new box and find out it was somthing silly?
Had exactly the same thing twice :rolleyes: your box is fooked mate :(
First of all try disconnecting the autobox ECU connector in the pass footwell, and reconnecting it, mine wasnt clicked in right once and the autobox didnt like it :nono:
is it easy to find ?? iam not the best when it comes to wires there all the same to me mate
Hope it pans out ok for you mate, i've heard stories of auto boxes
costing 1.5-2k to replace! If mine ever goes (touch wood!), i will
have the z-world manual conversion done...£1500 all in!!
Gotta be worth thinking about?
Yeah its the square metal box on the left, the engine one is on the right. Unscrew the bolt first, and dont do it up too tight when you replace it
i will try that.
any more tips it could be if not that ??
going to check and clean the filter aswell inside box, someone said check the tps ??
this 1
CHEERS GUYS FOR ALL YOUR HELP MY CAR IS BACK ON THE ROAD :dance:
THE BOX WAS OK BUT WHEN WE CHECKED THE FILTER IT WAS FULL OF SHIT
AFTER STRIPING THE BOX DOWN AND CLEANING IT BACK TO NEW THE BOX RUNS FINE.
ITS GOT SO MUCH MORE POWER NOW :hyper: AND SO QUITE AND SMOOTH.
ANYONE WHO HELP ME WITH ADVISE ON THIS BOX PROBLEM SEE ME AT BILLING SHOW AND I WILL GET THE FIRST ROUND OF DRINKS IN :dance:
P.S. IAM STILL AMAZED AT THE HELP FROM MEMBERS IN THE CLUB WITH HELP AND ADVISE MOST CLUBS ARE A BIT STUCK UP BUT YOU LOT ARE TOP LADS CHEERS FOR KEEPING MY CAR TICKING ALONG WHEN I GET A PROBLEM :bow:
Hey, It was nothing mate ;)
but...
It's a good job you ignored half the advice about replacing the box! :) :rofl:
Nice one :D pity mine wasnt fixed by doing the filter :(
glad to hear it was the filter m8;)
pity everything is not so easily solved:(
i was amazed myself when i changed the oil and cleaned the filter that it cured it, THAT noise deffo sounds more expensive
