Leaky Targa Top -
:confused: I'm getting a leak, particularly on the passengers side, and particularly when I brake. As my wife sits there most of the time I need to do something. Is is possible to get and replace the seals because they do look a bit squashed, particularly at the front?
It's so bad that, in the car wash, I have to hold a rag up to stop the water!!
Chris Davies
N/A J Spec Black, subaqua carpetting! and totally new to the 300zx
Its all easily replaceable but I would imagine expensive, might be worth asking AndyZ if he has a good second hand set or maybe one of the other traders can get them new cheaper.
You put your car through a car wash!!! You need to bond with your car by carressing its metal and wash it yourself, you also get a better job this way. Who on here would use a car wash??
Boy , you guys are weird!!!!!!!!!!!!!!!!!!
Chris
Chris
:confused: Wierd.....No my friend you should be at one with your Z "(said in a Grolch advert voice) :rofl: :rofl: :rofl: :duffer:
Agreed - my Zed never goes anywhere near a car wash! :o
As for the leak, is it definitely coming through the squashed seal or could the drain hole be blocked?
In answer to you question you need to speak to Mike Feeney. He should be able to source you a bran new seal or Andyz or Pistonheads for a 2nd hand one.
