can u get universal 02 sensors
can u get universal 02 sensors as mine not working right :cry:
cheers
Yes but I dont thing the resistance scale is the same as the ones on the Z.
the only prob is that the dealers want £230 for both sensor is that the going rate?
cheers
cheers
One side is a lot dearer than the other for some reason. even though they are exactly the same bar the wire is slightly longer on one. I actually think its the side with the shorter wire which is more expensive.
cheers lads for the help
you cannot beat good old courtesyparts.com they are fab!
Disconnect them at the connectors and check for corrosion - green stuff - in the connectors. Clean then re run the diagnostic on the O2 sensors - you can verify each side. I nearly bought a new O2 sensor then when I saw the price I rechecked and found a poor connection on the NS one. The connector is at the back of the plenum on that side. has 3 wires - red, black and white wire going into it.
Mines had the OS changed sometime as it looks much newer than the NS
