fuel injectors!
hey guys!
just done hybid tubs etc.
and think i need to go for a set of 555 injectors!
any particular makes better than others?
to fit them what is involved?
eg injector seat mods, wiring mod etc etc once the manifold is off will they fit straight in???
:bow: cheers guys
hey guys!
:bow: cheers guys
if your going for nismo 555's then they are a direct fit so just a case of removing the plen and fitting them to the fuel rail
Just make sure you get the right ones. '96+ were different.
yes i think nismo is the way to go especially if they fit straight on!
tis a 92 jap spec tt so do i need early type injectors? any one do some good deals on these???? please!
john d can you supply suitable chip ffor 555's
have already 3 chips off you for standard injectors( havent even fitted them yet!!!!
thanks for info guys! :dance:
speak to Chris at Getgreddy for the injectors mate
Its also recomended that you change the "o" rings too.
  • 5 months later...
Any ideas where I can get a set of these 'O' rings anyone?
And do I need any other gaskets etc etc to change the injectors??
Mark, I got my O rings from Concept Z in the States. Speak to Coz over there, he's a very helpful guy! To get at the injectors you need to remove the upper intake manifold (upper Plenum). To refit the plenum you need to replace all the gaskets....and it just so happens that I'm selling a complete gasket set! Check out my post in the for sale section mate and you'll see a list of what you need all for a price cheaper then anywhere else! :D ;)
Cheers,
Leigh
Should also say that you would be wise to replace the PCV valves while the Plenums off. You can also pick up the complete 5 piece kit from Concept Z or MJP.
Cheers,
Leigh.
Cheers,
Leigh.
Ah I see, well the mrs is yet to buy me anything for my zed for xmas yet mate so PM me so we can talk business.... :duffer:
And I will out another post up requesting a PCV valve kit and check those businesses you mention.... :duffer:
