R33 GTS-T disc/ caliper set-up
I have been offered some R33 GTS-T brakes (discs/ calipers). Looking at the specifications and searching other threads I think that these discs are only 296mm when the discs I already have from a GTR are 330 (ish).
Firstly, are the GTS-T brakes any good? Are they 4 pot calipers? Can I fit them onto the 300Z TT? Will the calipers fit over the GTR discs I already have???
I think the size of the 300 discs are 280mm so would the GTS-T upgrade be a good one or relatively the same???? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
:confused: :confused: :confused: :confused:
GTS are deffo smaller than the GTR and they also use the same pads as the Zed so no real upgrade there mate, GTR32 is the same as GTS as well, you need GTR33 or 34 as an upgrade.
smithy
Chris,
As Smithy Says, GTS calipers are the same as our stock ones.
Chris,
I rang Smithy this morning and although the dics are slightly bigger than the Z @ 296mm it is the same caliper set-up so won't really give me any huge gain on brake performance. :cry:
Still trying to get some calipers to fit the 330mm discs you sold me. Can't get a caliper bracket either. :cry:
Sourcing some aftermarket parts is a bleedin' minefield.
