Brembo sizes
One for any Skyline boys knocking about.
Can anyone confirm if these measurements for a front and rear set of Brembos (off a Scooby) match those for R34 Brembos?
Any help would be appreciated! :)
Front Calliper:
Calliper Height is 285mm
Pad Height is 133mm
Pad Depth is 60mm
Mounting Hole PCD 155mm
Rear Calliper:
Calliper Height is 180mm
Pad Height is 76mm
Pad Depth is 45mm
Mounting Hole PCD 115mm
Front Calliper:
Pad Height is 133mm
Pad Depth is 60mm
Rear Calliper:
Pad Height is 76mm
Pad Depth is 45mm
was looking at these on the GTR forum bit expensive considering they do not come with Discs which will be another £500+ on top
Yeah, you're right guys. Too much money considering there's no discs and the rears are going to be left sitting in the garage...the search continues...:(
