Just bought the coil pack and injector connector kits from courtesy. I have looked at these kits and looked at the car and cant see where the connectors at the end of the looms are? Also I have the temp sensor loom and need some advise on this as well please.
How do I go about fitting these? I hope these will cure my cars missfire on tick over. :rolleyes:
Ivan
ive done the injector ones & temp sensor- the kits arnt for our cars - theres no "connector" ;)
you need to cut the loom back - cut the connectors off the new loom & solder in! :)
I presume you mean the coilpacks, make a note on a piece of paper of the existing wires. You will also notice that each one is a different thickness too.
Don't forget to disconnect the battery when you do the injector's as they have a permanent live.
