All I can say is that, when Nissan told it's people that it had to go away and design the heater matrix for the Z32, I'm guessing that it was a punishment. :xxx:
Heater matrix went on Wednesday evening and immediately realized that I had a bitch of a weekend ahead of me. Called Nissan for a qoute, £180+....ouch, so decided to go for the second hand option. :x:
Anyway, after opting to do it with the dash in place, the further and further I got in to the job, the more that had to come out. This is a list of what I had to remove to actually get the matrix out:- :shock:
Push bonnet back past it's stop point with a bit of gentle persuation.(90 degrees)
drip tray above battery for easier access to....
Battery
Drivers seat (Suprisingly heavy)
Clutch Pedal
Clutch bracket
Clutch Booster
Panel under the drivers dash
Vents under drivers dash
Aircon control unit
Clocks( because the bracket/pedal would not come loose so needed to see what was going on from on top)
...and the bast4rd of the whole job was the screw that retained the feed and return pipes to the matrix that had to be accessed from the engine side.
oh yeah, and about a million screws.
After refiting the replacement matrix and doing a test, I got a nice gob full of antifreeze from the what had been standing after the spill(that's the thanks I get for undertaking this mammouth task). However, after a minute or so, all was dry...Hope it stays that way. I also descovered that you need the hands of a pixi to put the clutch booster nuts back on. In the end I discovered a new way of putting a nut back on a bolt with the use of a magnet and a steady hand.
After spending 3 and half hours on Saturday, and 5 hours on it today, following a stag do last night, all I need to do is put the clutch bracket and pedal and the cruise sensors and all the ducting. :dance:
However, it did give me a chance to clean some areas that I had not been able to get to before and, it has given me more confidence in doing work on it, to the point where I am contemplating keeping it as a track car and getting rid of the aircon and HICAS and the IRFR(or whatever the bloody hell it's called. Still can't decide!!!!! :cry:
Should have it done by tomorrow night - just hope the weather holds out as it did todya nd yesterday...Got a lovely tan! :D
BTW - Thanks to JeffTT and SMW1 for their help. :bow:
I'm glad I've started drinking more! :duffer: :duffer: :duffer:
OMG - what a weekend I have had!
Battery
Clutch Pedal
Clutch bracket
Clutch Booster
Aircon control unit
