Well Forked Off
Just had the plenum off to sort the problem out checked all the hoses,plugs and gaskets and the forking thing still will not tick over it just give up :xxx: :xxx: :xxx: Who the fork can fix this in the north west :bow: because I've about had it :mad: :mad:
everthing was ok before I took the plenum off to change it for a polished one
it will run with a bit more rev but will not tick over
Is the tps at the correct voltage ?.
Have you got an air leak somewhere ?. Any obvious hissing ?.
Probably point the obvious but it's all I can think of at the moment.
