lowering Springs
Can anyone one recommend the best set of lowering springs with the best price?
Depends on how much you want to lower it.
Chris is an Ebach (Is that right?) spring dealer now.
Just fitted the Eibach Prokit with new stock shocks and am well pleased with both looks and handling.
Wouldnt reccomment them on stock wheels though. cars too low
My 18"s seem to raise the car to its normal height while lowering the distance between wheels to Arch
Also consider getting progressive springs - compensates for the loss of travel somewhat.
The car should be the same height whatever size rims you have, because you use lower-profile tyres to maintain the same tyre circumference. If you haven't done that your geometry will be out before you even change the springs!
