Just changed the plenum yesterday put it all back the together and in just will not tick over ,it starts last for 1 min if that .Any ideas what I've fogot before I get the forking big hammer out :xxx:
it looks ok,
ungrateful forking car
Connected the idle valve at the rear passenger side of the plenum? Yellow connector :) Also check the other 2 connectors on that unit - FICD and air regulator...
Checked all hoses are attached? Will it run if you use the accelerator?
Andy yes
how can i test the lead to the injection plugs and spark plugs with a multi tester or is there a way to do a ecu self test
Andy will have the strip it down again on Friday to see if I've missed something .so wait for the mails
thanks wez
