protoj · 13 hours ago 13 hr
A good source of technical information.for modifications and upgrades on turbo engines and suspension etc can be found in the performance books published by Bentley publishers. WWW.bentleypublishers.com
I can recomend "Maximum Boost"
a good book on turbo systems.
Dazz..
