H, PCD, Offset... ??????
does anyone have a guide or a link to a site that explains all these terms used for alloy wheel specifications? or is someone able to explain them?
also what spec wheels are needed to fit on the zed? is it only the offset that needs to be correct?
cheers guys
yaseen
OK chaps, read and destroy... I've attempted to answer this by writing a FAQ. :cool: Feedback welcome, and I'll edit appropriately.
http://www.300zx.co.uk/forums/showthread.php?p=276394#post276394
What other wheels fit (or might fit) straight on - I'll edit the final list into that FAQ. I can think of...
'liner
200SX
And different centre bore - usually not a problem:
RX7
MR2 and Supra
350Z Rays offset is too small - but only just... might get away with it.
http://www.350zmotoring.com/forums/Wheels_and_Tire.php
great stuff bud. really informative and impressive, just need some pics to help wot ur explaining about offset (nick em from that website lol)
thanks
yaseen
"Offset
+35...42 mm"
does that mean u shouldnt get negative offset wheels for a zed? only offsets between +35 and +42?
"Offset
+35...42 mm"
Correct!
You can get something with a smaller offset and use a spacer, so the whole wheel sticks out a bit more than it should, but that's as much of a hack as it sounds. Personally I wouldn't if you plan on going round any corners. :rolleyes:
No way will neg offset fit!
(And ta for the feedback, and I might doodle a better diagram at some point...)
i get it now! finally :cool:
thanks alot
