Anyone fitted Harve's camber kit yet?
I'm hoping I can put a spacer in and get it pretty close before I take it for a check/alignment.
I think Harve said that for 25 to 30mm lowered springs you will need roughly a 6mm spacer.
Has anybody tested this out yet?
I've got Blitz Super Traction springs and I'm not sure what drop they give.
I did a search and someone mentioned they are 15mm at the front but this doesn't sound like much to me.
Any ideas chappies?
Nah, I've got some of these on the way :D
:D
They're shiiite Andy!
You're much better off with a spacer jammed down the back of the bolts like mine :D
Are you going to paint them brown before you fit 'em so they don't stand out too much from the rest of your Z? :rofl:
Chris, try the 4mm spacer for starters ;)
Andy, there nice-were they expensive?
Ya5een you should cruise the forums more -see GB forum.
All those who have bought & payed for kits, thanks for the kind feedback :)
Those who have recieved kits & not payed yet - its the end of the month payday! YAY!!! ;) If I could put it politer!
harve
i was thinking ov lowering mine does anyone no how much these camber alignmnet things cost.
That's what I was going to try.
Hopefully it will be near enough first time when I get it tested.
Phil,
The camber kit that Harve is supplying is only about £45 I think but if you want the "proper" kit that's adjustable on the car like Andy above then they vary from £300 to £500 :eek:
Still not much to pay when a pair of 18" front tyres can be £300 and wear out in a couple of thousand miles if no aligned.
I found out the hard way.
It does depend on what size wheel and how much you lower/how sagged your springs are.
