quick question
does the 3oo need the system bleeding after a coolant change or is it a case of just putting the coolant straight in ??
thanks craig:D
thanks craig:D
Top left of radiator is a plastic screw, with a philips head screwdriver you take this off and fill radiator.
cheers bud ;)
Any news on the water problem,would allso be good idea to fit new rad cap,especialy with the warmer weather,take look at cap washer seal,if it looks like rubber is frayed/pited/perished/deep round grove were it sits on lower rad neck then bin it,just so happens i have a Greddy one used it for only a month,if you need it £10 :D
Tony
it took me about 5 hours of checking every 30 minutes to fully bleed my cooling system. I had drained the whole system though.
5 hours :( i wont be draining the whole system (well hope not )
ive just got a intermitent leak somewhere only when u switch the engine off :cry:
if anyone from daventry wants to come and give me a few pointers 2moz feel free lol :)
wheres it leaking from? mine was the water pump and i replaced that last weekend, took about 12 hours altogether. I could probably do it within 6-8 now though that all the problem bolts have been replaced + i know what im doing.
unfortuently im a long way away from you.... but you are best to get it diagnosed.
Shouldn't this be in Tech/Help and advice?
yae it should have been but we all make mistakes dont we :bow:
Craig, just emailed you my number - gimme a ring tomorrow early afternoon bud :)
Pete
your not going to give him Motorway distance instruction are you :shock:
