Right, thanks to all those guiding me towards the leaky DV probs.
Stalling problem has now gone away (on a short test drive)
however . . . . .
Still got no boost
Cant get above 5 psi now - same as before i replaced the DVs for the original recircs.
Even putting boost controller on 1 bar on will not raise past 5psi
ideas??
You reset the ECU???
Just a thought.......
Matty.
Mr Dixon has said he will help out with that. Ist just another long journey, down. I seem to spend more miles in my car taking it for fixes than anything else.
Before I trek down, any ideas on which pipes I need to start looking at. Is it likely to be one of the 3mm vacuum pipes or one of the large 4 pipes at the front near the rad?
Ta
Jay,
If it's leaking that much it's more likely to be one of the big boost pipes than a small vac line. Check the rubber hoses where the turbo outlets are joined to the hard pipes and the ones on the throttle bodies / intercoolers.
Ta
VERY true!?? :( :( :( :( :( :( :( :(
