Blown Water hose!
Hi All, I have a 300zx Twin Turbo, but for the 3rd time now it's blown a hose :cry: Is this a common fault or is it that the car is old (1990)?
Can somebody please advise..............problems and replacement hoses?
Steve
snap mind has just gone on the way home
Which hose has it blown?
No its not a common problem
I haven't had a look yet......sorry?
It's a bummer when it happens, you are unable to drive the car?
steve where the water coming from? ,just had a look at mind and it the front by pass hose they are behind the cam cover.Phoned nissan up they cost about £5 each easy job parts here in the morning ,will have to phone in sick again like today :dance: :dance: :dance:
Hi Wez..........do you have a number for Nissan? The water appeared to be coming out from the middle of the engine, my only concern is that it looked as if it had petrol/oil mixed in with it?
Steve
steve
I phoned the local one in St Helens (cup winners),may be the same pipe, the oil /petrol could be the years of spilled stuff from under the plenum may be live in hope
Hi Wes..............I've manged to get a pair of ramps and trolly jack :) So I will be looking tomorrow night at it.
Whats the best way of identifying the hose, by filling up the engine and running it?
Steve
Unless you can pressurise the system without running the engine. Yes.
Thanks for that...........roughly how long can it be run for before damage?
Wes,
Allow yourself some time for that mate, its not as easy as it first seems, putting those clips on is a b@stard, but it is a good time to take the thermostat out and give the waterways a good flush. Also take some sanpaper to the ends of the pipes on the engine, they get furred up something cronic.HTH
Jock
spoke to soon the bottom has rounded off does the inlet pipe run water through where the bolts are or just through the rubber pipes .Just started to clean the outlet up the ends were furred so cleaning the whole pipe up with the b&d
Wes,
steve
any further on the water leak.Finish the one on my cay as Jock said the clips on the hose where a bit of a sh*t ,but why it was in bits did a bit of bling polished the two water pipes and sprayed the the cam cover and fan shroud sliver ,looks a bit cleaner .Next thing to polish is the plenum ,sorry steve again any news
