dave i set mine easy you just twist it on the bolts only a bit at a time
test the voltage on full and no throttle
do a search there is a link on how to do it on here
see you saturday
steve
see you saturday
steve
Steve thanks for that dare i ask hows fem!!
cheers
Dave
How can this be carried out mines a little low at presant
cheers
Dave
Dave,
This should be a 2 minute job with your ConZult.
(1) Hook up the ConZult
(2) Run engine
(3) Go into "Idle/Throttle adjustment" screen on the ConZult software
(4) Undo (but do not remove) the two screws securing the TPS
(5) Turn the TPS unit clockwise/anti-clockwise until the voltage is just below the point where the "closed throttle/position" switches from off to on (this should be at roughly 0.42~0.44V)
(6) Tighten up the screws (making sure the voltage doesn't change) and Job Done!
NB - when turning the TPS you'll notice the point where the "closed throttle/position" goes from "off" to "on" because the revs will raise to about 1100 rpm. You want to set the TPS to the position just before this raise in rpms occurs.
Hope this helps fella!
Regards,
Danny
cheers
Dave
in bits last time i spoke to the guy
ill ring him tomorow to see when ready
suspect it was finished friday
and hes been out cruising and picking up ladys
steve
Good.......see you saturday i hope ...will be working in the morning probabley get there 1.30 ish will miss all the good stuff :cry: :cry:
cheeres
Dave
