Fitted the new dampers-ok-, but where on earth do you possition the electric motors ???
Motors work fine in turning the 90 degrees required, and fit on the bracketry fine but you can adjust the damper shaft & motor shaft. Im conserned in case 1's going stiff as the other going soft. (doors open there, but how else can I explain it)
Hi guys,
UK car all std (new) bits.
cheers
harve
