Idle Problem - Desperate Plea for help!
Ok guys, again several issues, but i'll start with the most important and then do the rest in other threads.
Car was running perfect until i gave it a little snot, got it home and it started idling really badly, it now stalls if you leave it a few seconsd without compensating with the accelerator. While ildling it's badly misfiring, which is why it grinds to a halt.
I'll be honest i havent got a clue about it car, it like learning Japanese (pun intended). Where are the HT Leads? Spark Plugs?
I've looked on a few other threads and you guys keep mentioning the O2 Sensor? where is it and what does it look like?
Desperate here guys, i dare not drive it until its sorted.
  • Replies 29
  • Views 1.4k
Errrmmmm hang fire one minute - which plug did you disconnect? Its the GREY plug on the flying lead you need to unplug - the other is simply the hard idle contacts and won't really affect anything that much... ;)
See pic below, thats the connector i took off to test, no change to idle at all.
Yup thats the wrong one to disconnect! How many new TPS are on their way to people on here now then? LOL Find the lead that comes out of the back of the TPS, follow it for about 2" and you'll find a grey connector - unplug that see what happens ;)
ok if i plug the connector was is supposed to happen if its working? ANd what is supposed to happen if its not!?
