Welding
Need to do a small weld on the Z before the MOT. Should you always disconnect the battery or does it not matter?
Disconnect the battery or replace all ecu`s when you`ve finished welding, POP, POP,POP,POP,POP, POP,POP,POP, POP, POP,POP,POP,POP, POP,POP,POP. Is that ecu`s I hear. :rolleyes:
I have the same question... so do you disconnect both terminals or leave the earth on??? does it matter?
