Spark generation????
Please can someone explain how the ignition system works (in lay mans terms ish)....
Previous only used to dizzy cap/rotor arms/HT lead set ups..... all looks a bit complicated on the Zed...Forgive my ignorance..
Regardz...
On the Z every sparkplug has it's own coil..
each coil is driven/actuated by the PTU (powertransistor that amplifies the current high enough for the coils to generate a spark)
The PTU is controlled by the ECU
The ECU gets it's information regarding RPM and camshaft/crankshaft-position through the CAS (Crank Angle sensor)
...So basically the dizzy cap + rotor are replaced by the CAS
-Eric
Hey Eric,
I knew you would answer this one even before I scrolled down to view your post smile.gif smile.gif
Steve
