clutch issues help
sussed had no clutch fluid
couldn't get into any gear
need to know where the master slave cylinder is situated
can i access the lines on axle stands as my mate needs to bleed the lines as there is air in them
obviously can't move the car and take it to a garage, so doing this on the driveway is the only option
I need to tell him by the morning, so we can put my car on stands in our lunch break, finish it off after work
how long does it take approximately to get the air out?
for future reference I don't understand where all the clutch fluid went
At least i know where to top it up now!!
Learning curve number 63
Hello you.
Master cylinder is in engine bay, bolted on the bulkhead in front of the clutch pedal. there should be a tiny reservoir for filling up the fluid.
Slave cylinder is found on the gearbox, underneath drivers' side. There is a bleed nipple on this.
There is also a bleed nipple in the front right hand wheelarch, somebody please help me on this as i have never had to bleed mine using this.
Will post some pics if i can find some usefull ones.............
Robert & Wendy
Yeah, you can easily bleed the clutch, just by jacking up the drivers side of the car. Instructions are on my site and also in the online manual.
ok....... this is your brake reservoir.....
http://bagpuss.swan.ac.uk/dunk300zx/Z32_Pictures/DCP00244.JPG
Towards the centre of the car, and down, there is a smaller one. this is for the clutch.
http://bagpuss.swan.ac.uk/dunk300zx/Z32_Pictures/DCP00373.JPG
http://bagpuss.swan.ac.uk/dunk300zx/Z32_Pictures/DCP00911.JPG
Clear as mud no doubt....... sorry :S
ok found clutch fluid, it didn't have any topped it up
my mate is going to bleed the lines tonight been on a few diffrent sites there are 2 points to do this, is this correct
the procedure looks fairly simple enough i just want to make sure that i can tell him exactly on a zed where the bleed lines are, as he's not that familar with zeds
any thing else i need to know
Yeah, if you spill DOT5 over the engine bay it stinks and it looks like your car is overheating. ;)
Have you found out why it disappeared? I had a split pipe. :( (By a strange coincidence, it started after a 20 mile crawl round the M25.)
where do i buy pipes/ lines from
Sometimes getting the last bit of air out the slave cylinder can be a pain. I remove the slave cylinder, turn it round so the bleed nipple is at the highest point, clamp the piston/rod in place, bleed it again and then re-install it.
sorted :D
sorted out all the air from the lines clutch feels so much better
bloody ell you could have warned me how knackering it is to pump a clutch :eek:
thanks to Toby, Andy Duff and Magnum 5 and everyone who replied to my thread for all their help :hyper: thank you!!!!
woohoo
