gearbox oil??
i've done a search and recommended some gear box oil
can i get it at halfords?
where do I put it? ... no rude answers
My zed's gear stick, is really stiff, especially in the morning, before i start driving took me good five minutes to get it into 1st gear, blooody knackered now...
after that while driving it has been absolutely fine :confused:
or might it be my clutch?
will it ever bloody end?
if this might be serious :rolleyes: tell me
dufflecoat where are you?
Sounds a litle clutch-ish to me ...
Incidentally, I'm also considering which oil to put in my brand new box when it's fitted. Suspect I'll go for the expensive fully synth option ....
I got some Redline MT-90 from Demon Tweeks which I think was £12 ish for just under a litre. This is supposedly the best, but its not in yet so I can't say for sure.
I've also brought new shifter bushings, boots & lever plate from nissan, as my lever was fine when cold, but reluctant once warm + noisy in 2nd & 4th - if you want the part numbers I'll post them.
or you can get it direct from the distributor:-
Technical Sales Manager
Delta Oil Ltd.
Red Line® Synthetic Oil European Distribution,
Market Overton Industrial Estate,
Rutland, LE15 7PP UK
p: +44 (0)1572 768311
f: +44 (0)1572 768249
e: info@redlineoil.co.uk
Vijay
