Ever since owning my Z, the cruise control has never worked. It has had an auto to manual conversion (done before I bought it) so can only assume it is something to do with that. Has anyone got any ideas as to what I can try to get it working? :(
Going on holiday in 5 weeks so would like to get it sorted before then if possible.
Erm yeah ... mine has also never worked since the auto/manual conversion was done. One day when I'm feeling clever I may work out why. Perhaps it's something to do with the clutch switch or the redundant autobox controller flashing error codes now it has no box to chat to ...
Erm yeah, mine has also neer worked since the auto/manual conversion was done. One day when I'm feeling clever I may work out why. Perhaps it's something to do with the clutch switch ....
if it is then just shorting the 2 wires should sort it
Could be, it is there and it is connected and I also connected up the neutral switch, but so far it's not made any difference.
Mines not working either, been OK untill last week, when the horn stopped working as well.
Fuses OK and wiring seems ok, also sprung connectors on the back of the S wheel look ok and making contact?
