Spark plug help
ok, for my service im changing plugs, I can't really find the information i need on here
NGK code is pfr6b-11
there are ratings for
standard
cold
hot
what is the difference between the three, the best one to use, and the pros vs cons :D
As far as I knew if you run more boost you are meant to run a colder plug.
try here for more info
http://www.extrememotorsports.com/plugfaq.htm
Here's a typical NGK spark plug part number: BPR6EVX-11.
A quick run down of the part numbers. Each letter or number has significance in the NGK part number, but the same letter may hold a different meaning depending on where it is placed. Here is a rundown of our part number:
B Thread diameter = 14 mm
P Construction = Projected Insulator Type
(K) Construction = Hex size 5/8 in, projected tip
R Construction = Resistor Type
6 Heat Rating Number = 2 Hot -> Cold
E Thread Reach = 12.7 mm
S Firing End Construction = Standard 2.6 mm diameter center electrode
(VX) Firing End Construction = High performance platinum
(K) Firing End Construction = 2 ground electrodes
(N) Firing End Construction = Special side electrode
(-11) Gap Width = 1.1 mm (0.044 in)
pfr6b-11b is the stock plug. For colder you need something with a 7 in it (if it's an NGK). Normal recommendation is one range colder fo every 50-100bhp over stock.
I use ZFR7F-11 coppers, BKR7EIX-11 irridiums also work.
Just about to put these coppers in mine to
cheers guys ;) guess ill stick with standard until the clutch and boost upgrade
