Profec e-01 install
Okay - I read the How to install the Greddy Profec B II FAQ
Question is.. is it the same for the Profec e-01?
Also which pipe do you T into for the boost sensor - the FAQ says this one yet on another install its this one (marked with a green dot) - which is best the one with the Green dot or the one with the Blue dot? Does it make a difference?
CheerZ
/\/\ark
Whichever vacuum pipe suits u better it doesnt matter
Hey - a response!
Thanks Pambos - just wanted to be sure before I started cutting hoses
I usually try to use the one that goes to the stock boost gauge (far left of balance bar).
It's because I don't think it's a great idea to tee into the ones that go to the FPR and pulse damper because if the line comes off you lean out.
