Autobox cooler for Jap n/a
Has anyone installed an autobox cooler for an import n/a ? The kits that Luke sells are only good for the UK car which has already an engine cooler. I spoke with Luke who said that the problem is that the Jap car has no exxisting mounts, so special ones would have to be made, which can be a bit of a problem if you do not have bending,cutting facilities in your garage at home.
John
Someone surely must have installed an autobox cooler for a Jap non-turbo ? I think I can figure out the parts I need, its just the mounting of it I am not sure about, being as the n/a has no engine oil cooler or brackets up front.
John
Just pop to B&Q and buy some aluminium strips and make your own fitting bracket.
