Fitting of dump valves
Hello,
Finally decided to buy some dump valves with fitting kit supposed to be a straight swap apart from pipes being blocked? and am just wondering if there are any sites on how to fit as i am a novice on these as i have never used before.
Thanks again.
Ant :confused:
hi antf what do you mean by ''the pipes are blocked''
jim
jim
Sorry i re read it and it wasnt clear, the vague instructions i have is that you have to block off one of the pipes??
Ant
Hello,
Thanks again.
Ant :confused:
What sort of valves did you go for? Im just looking at going to get some in the near future.
cheers Jonce
[sIGPIC][/sIGPIC]
cheers Jonce
Not sure of the make but this is the description:
two Stage II Adjustable Blow Off valve with Adapters for the 90-96 Nissan 300ZX Twin Turbo , again included are two Aluminum Adapters for direct fitment into existing Hoses that currently hold your Factory Compressor Bypass Valve located under Air Filter Box. No welding required, simply direct replacement so no headaches for installation.BOV's are made of Aluminum CNC Machined, they have Brass Pistons and are of very high quality.
Havent received them yet as they are being sent from america only cost £130 including postage for 2 and fitting kits.
Bargain. :hyper:
basically you have got the Dump Valves that go in place of the recirc valves. Similar to the SQL HKS ones.
Check this page of my site for full instructions
Excellent thanks, are these type of BOV's ok?
Looked at your site - excellent and very helpful thanks, specialy like your vinyl exactly the same as mine that i have just finished ;) Got mine from Romford too.
Just asking, as from your site you say you have the consult, is there any chance we could meet up and test mine as i'd like to know if i have any probs, obviously i'll sort you out.
Thanks again
Ant :duffer: :duffer: :duffer: :duffer: and so on!!
Ant any chance you have the site where you got these valves from as that looks like a good prices
Got them from ebay.com just type in 300zx blow off and they should pop up the are blue and are for buy it now at $189.99 the seller is Progear2000.
Hope this helps.
Ant
:slap:
try this link
http://www.300zx-mods.co.uk/BOVS.htm
they have some very helpful tips. But i don't understand why mine are fitted in the engine bay rather than under the nose cone does this mean i may have two sets.
Why is this?
The stock recirc valves will have been removed and blanked off.
BOV's (like recircs) are meant to be fitted as close to the throttle bodies as possible so that's why they are often moved up top.
Also you can show them off better that way ;)
Hope this helps.
Ant
:slap:
Ant what make are they and how long will the shipping take
It doesnt say make, i think they are this guys own type he does three models.
I ordered them on Monday and they were sent on Tuesday I paid $41.75 for the 3 - 5 days tracking postage so hopefully be here tomorrow if not monday, i paid £130 overall in total.
Ant
has the kit turn up yet ,found the site looks like a good deal .will wait till you have fitted them (guinea pig) before I send for them keep in touch
Ant
Wez,
Looks like they will arrive monday (fingers crossed) as the tracking on the net shows they cleared british customs on friday, hopefully fit same day and will let you know what there like, just hope they dont make the car stall. Have you got a direct email so i can let you know sooner rather than posting on the site.
Ant
Post on the site how you get on as I'm sure a few people would be interested to see if they are too good to be true or not... if they're not, think I'll be ordering some too!
Cheers,
David
Hi anyone know where to get the turbo hose(aluminium one) so that i can attach the blow off ?
