3 days and broken!
Had a very broken thigh bone for the past 8 weeks so not been in the zed much. 3 days ago the doc said i could start driving again :hyper: . Today gave it a bit overtaking a learner car it was fine and got home and it was still fine. 1 Hour later came to turn it on and it sounded sh1t, tried driving it but after about a mile it sounded as if it was on only 5 cylinders. ECU diag gives 55, no smoke on boost or idle at all, but when i checked the plugs one had oil on it. :nono:
Is this a sign of a dodgy valve seal? :confused:
If so is there anyone in the morecambe to preston area that could check/repair it as i'm not quite fit enough to take the engine apart, and thats about as far as i can drive at the moment.
Thanks,
Stuart.
Doesn't Andy Duff reside that way ?
Hope you get it sorted, mate :cry:
Richard
I didn't realise Mr Duff still did Zeds..........If your out there Andy could you help?
Clean it or replace it and try again - it was maybe fouled from lack of use and once fouled it wont fire - it just gets worse - worth a try
