April 14, 200422 yr Hi I am looking at buying the Speed convertor from the Z Centre and have a couple of questions. 1) Does the delimeter allow the car to go above the restricted 180 Kmh on Jap Imports 2) Does the convertor have an effect on the HICAS system. Cheers.
April 14, 200422 yr I just got one in the post today, Luke said it would take the limit away also that annoying beep when you go over 100 KPH and change the clock to read MPH. I will be putting it in tonight and will tell you how it works.
April 14, 200422 yr :cool: Luke fitted one to mine when i picked the car up and i haven't had any problems with mph or the hicas.....:D
April 14, 200422 yr I have got one on my import, I have had no problems with it. Got mine through a company called Outlander Products. http://www.outlanderproducts.co.uk
April 15, 200422 yr Did mine last night, it only took about an hour to do, very simple! Everything works great, converted the clock to MPH, takes away that annoying beep and limiter is away. No probs with the HICAS
April 15, 200422 yr Just check this thread out first, http://www.300zx.co.uk/forums/showthread.php?t=31176 You might find it interesting, as it's not as expensive as you may think ;)
Hi
Cheers.
