front brake pads
Just looked at the left front brake pads, outside ones are worn a hell of a lot more than the inside ones, does this suggest seized pistons on the inside?
When I replace the pads, should I be also be doing a caliper rebuild? if so, wheres the best place for caliper kits and standard brake pads?
John
  • Replies 40
  • Views 976
John
Hi Dixonjohn, I've just changed my front pads. Got mine from Jeff at ********(Black ebc Kevlar). I know he does caliper kits. The black pads wear the same as normal pads but suppose to be more responsive.
[sIGPIC][/sIGPIC]
Hi John,
Ive replaced many brakes on various cars, and i have found quite often one side slightly more worn on one side. You'll be able to tell if the inside is seized as when replacing them, you wont be able to push the piston back in. I once had a seized piston on a rear disc of a vauxhall cavalier gsi. It wouldnt move an inch and the rear disc became rusty on that side of the disc as the pad wasn,t moving.
Jon.
yea, the inner pistons on both my front calipers were siezed solid. rebuilt them with seal kits from courtesy - i was amazed by the difference in braking after i done it!! :)
Paul,
I get the feeling that mine must be........almost a 1/4" more meat left on the inside pads
John
I was just checking Courtesy's site for price comparisons, they only list 2 caliper repair kits, one up till 1992 and the other 1993 onwards. I thought turbos had different front brakes, are the calipers same for turbos as n/a ?
John
Your right Paul, after checking Courtesy site again after 1991 all brakes are the same.
John
Dont get EBC Black stuff's they wont last 5 minutes before you need to change them.
Ok, how much are nissan ones? or what other make should I go for?
Do I really need the caliper kit if a couple of pistons are seized? I could just dismantle, clean and re-assemble couldnt I ?
John
£90!! is that for front and back? Theres no way Im paying that just fro front pads.
John
cheap skate :nono: :nono:
i put standard ones on mine false economy last 3k
will be upgrading this time
steve
LOL, the rears are about another £80. :D Good job I didn't quote the expensive ones. :D
You can get blueprint (OE pattern) ones for about £15-20.
steve
Steve,
When you say "standard ones" do you mean Nissan ones ? Surely standard pads for the street should last a bit.
John
john
your right they wernt from nissan
i think thet were minex or something like that
i put nissan ones in my old 300 they were just as shiyt
they might last a bit longer in a non turbo
steve
jez
those calipers look good
will i get to see them next sunday
i might look into doing that
steve
john
steve
Why would brake pads last longer in a non turbo :confused:
Depends how you drive.
John
no mate they are not mine, but you can see my chipped rough assed black painted ones. :D I might but my big discs back on too if I can be bothered.
Mintax do lots of grade, std, probably something between then... 1144, 1155, 1166, 1177.
John
same brakes less power to try and stop
yes your right its all todo with how you drive
as mine is a auto brakes get used hard
but ive had lots of nissans and standard brakes are always crap
steve
yep nissan brakes are poo, i've got zed brakes all round (brembo discs, castrol SRF fluid, and Mintex 1155's on the front std on rear) on my S13 and they are still shite, must be really bloody awful on a Zed.
I put stock (genuine) pads back in my rebuilt calipers, personally i dont find them too bad. but then 4 out of 8 pistons were siezed before then so what do i know??? :D
Has anyone else found that the black EBC kevlar pads wear out in no time?
John
John
In the last year I have used
EBC Red Stuff
EBC Carbon Kevlar
Mintex
Nissan OEM
Metal Matrix
Porterfield
To be honest they are all crap apart from Metal Matrix which are not to bad and the currant ones I am using which are porterfields which do seem to out brake all the others by far, espeacialy when warmed up
Ryan
EBC Red Stuff
EBC Carbon Kevlar
Mintex
Nissan OEM
Metal Matrix
Porterfield
Ryan
Thanks Ryan,
I dont push my zed too hard, so I probably dont need the pads with the ultimate stopping power when heated up, just a good all round pad for street use that will last reasonably well.
John
