Faulty Temp Gauge ;-(
Got a temp gauge thats not workin....can any one help....should i be searchin 4 a hidden fuse or somthing else.............. :confused:
How you know the temp gauge is not working?
There is no fuse for it.
Theres no movement in the needle on the temp gauge when the ignition is on and the acr has been running.........what d u think it might be
bad connection on the temp sensor, on the top rad pipe there are 2 connectors, a yellow one which feeds through to the ECU and the other one is for the dash gauge, take them off and give them a good clean, chances are they are covered in corrosion.
It could be your thermostat is broken and the engine is not warming up.
Start the engine and earth the connector to some where. The needle should go to the top. If it does, there is nothing wrong with the sensor.
The dash one is the black topped sensor.
