Help!!!!!
[undefinedundefinedundefined
:shock:
Help I need Help!!!!!!
I have just purchased a ZX for the first time at the weekend,
it came with part of the oringinal stereo in it. it was F****** so fitted my nice spangeley Apline head unit, but now only the front speakers work, used a converter cable from Halfords too.
Anyone got any ideas why or know where i could finr a wiring diagram for the car??????
Many thanks
Dave
:shock:
Many thanks
Dave
Hi dave, met you outside south coast wheels at the weekend. how's it going?
as for the stereo problem, you say the PART of the original stereo was nadged. do you know if the rear speakers were working to begin with? incidetally congrats on the purchase of the zed :cool:
i know but i have replacement speakers to go in the slots that u can hear...
Dave
I think that the rear speakers have built in amps so you will need to tweak the existing wiring or run new speaker cable...
UK cars (not sure about imports) have an amplifier for the rear speakers. So just connecting the adaptor cable means that the rears won't work as the live feed for the amp is no longer connected. Use a scotchlok connector to join the accessory live (for electric aerial) to the power feed for the amp.
That way you can still use the factory amp and do not have to by pass it and connect the rear speakers directly to the new head unit.
Steve
'93 UK TT Manual
hello matey, yeah its going great. getting used to the rear in the wet!!!! what fun!
yes they did work, and still do when connect up original stereo. stupid....
have got volt meter on it too. nothing!
cheers, cybernet. where is the amp located?
I know this sounds obvious. Count the wires coming out of the new head unit and make sure it's got the same amount as the car end so to speak.
I don't claim to be an expert, far from it. As to the idea that the rears have a seperate amp. I don't think the imports can have one. I fitted my sony in place of the jap unit and I've had no probs like this.
Jase
Now this is the silly bit! there are 5 wires at the stereo end and only 4 at speaker end. oh and to make things even harder the wires at the stereo end don't match the speaker end wires.
dave
Jase
Jase
The rear amp was standard on UKs and an option on Japs.
Steve
'93 UK TT Manual
Sounds A Dumb Question....... Where Is The Amp?
Dave
All the relevant info is in the link I posted above.. Some cars have an amp for each speaker, others have it on the right of the boot space
Steve
'93 UK TT Manual
If you are replacing the speakers, you should run new/better speaker wiring anyway.
This will bypass the amp problem.
