Over since the moron hit the drivers side of my car my clutch has seemed heavier than it used to be. Is there anything under the wing that is part of the clutch booster system, such as some vacuum piping.
At idle there always appears to be a bit of a whistle coming from the driver side rear of the engine bay. This takes a fraction of a second to stop after the engine is switched of. I've changed all the 4mm vacuum piping around here in an attempt to stabilize the idle, but no luck so far.
