March 23, 200421 yr hi ive just had to change my cam belt n water pump but how on earth do u slacken the cam belt tensioner to put new timing belt on??? :bow:
March 23, 200421 yr In the pivot arm there is a threaded hole, get a 6mm bolt around 20mm ish long, and screw the bolt in, you will notice it start to compress and relieve the tension on the belt. I think there is a write up on twin turbo net on it mate
March 23, 200421 yr many thanks i will lok first thing once again thanks :dance: In the pivot arm there is a threaded hole' date=' get a 6mm bolt around 20mm ish long, and screw the bolt in, you will notice it start to compress and relieve the tension on the belt. I think there is a write up on twin turbo net on it mate[/quote']
