fan shrouds
Hi,
Does anyone know if there are different ones? got a new one to go on and it's different, have I been given the wrong one?
Vijay
Know there are two different oem radiators that I have seen, the na that I have is rounded, whereas all the tt ones I have seen are square, so that may meen a difference in the shrouds
The Euro spec fan is larger than the US fan and so will the fan shorud be. I am not sure about the Japanese spec fan, but I think its the same size.
it's defo not a US shroud, the cars a UK and the shroud is either jap or UK.........................................
Vijay
Vijay
Vijay mate, If you find it's an N/A one I'll have it off you.
Chris..
Cheers guys. This bit circled in yellow is the problem bit, I've checked on 2 tt's and it doesn't have it.
Chris, is this the same as your NA?
Vijay
I suggests a smaller radiator....mine certainly doesnt look like that on my import TT.
Cheers guys, NA it is then :)
Chris, if you get a TT one off Andy Z, then we can just swap them over :)
Vijay
