Att Vijay RE: Dials
Hi Mate,
Got the dials today :D.
Have I done something to upset you :confused: ?
You seem to have shredded the instructions on how to fit them :rofl:
Thanks mate they look spot on..
On a serious note.... where's the instructions :p
never did like ya :D but if I must here's some instructions -
http://www.neuralmotion.com/forum/tech/idial_install/idial_install.htm.
You'll see that you can actually take the clocks apart. I removed the old
face just by cutting it in half with a knife, which gives the faces more
clearance. The dials will go over the needle, it's just a tight fit (I
promise, I've done a set of clocks).
Also, if you want to wire them up so you can use the light dimmer switch,
here's how to do that -
http://www.twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=644459
Any problems, let me know
i also thought they wouldnt fit but after a bit force they went on a treat ;)
thanks again vijay the dials are the muts :D
good, glad you're happy. They do look the nuts when lit up!
Vijay
