Bored at work????.....
......then why not waste a few hours here;
MOTAS
Warning, can be very addictive and waste lots of your company's time!! :nono:
  • Replies 56
  • Views 1.9k
I remember playing this some time ago .. enjoyed it very much
Really good if you are bored at work as it took a couple of hours I think to finish, then again I am of the chimp :dance: :dance:
How far have people got? Im stuck on the keypad with the smiley faces on.
I've completed it.
On that keypad, one of the buttons is the right one and will take you through to the next keypad. If you click the wrong one it takes you back. Just start in the top left corner and start clicking. (Hope your memory is good!!)
how the hell do you get out of the 1st room ?
Something under the pillow or something. Put the poster under the door and use a screwdriver or something in the room to push the key though, pull the poster and it will have the key on it.
Pretty close, it's actually get key from under pillow, open locker, open box and get screwdriver, use screw driver on painting to get screw, get poster and slide under door, use screw to push key out onto poster, slide poster back to get key, use key on door et voila!!
Oh, you are going to hate the later levels!! :rofl:
What do u do with the pen and paper on level 7?
whats the code for the room with the plant in? 2nd room
You get it from the PC. You have to put the disk in though!!
I'll just say that you can trace something with it to order something!!
Ok, these smiley buttons are doing my nut!
How many button presses do I need? My brain's gone numb after 22!! :confused:
i'm stuck with the tiles and the rat... does the floor tiles mean anything
yep im stuck here too, ive stuck the stones under the stairs and moved them about, what are you supposed to do with them?
no idea i've got as far as you the rat head thing and the carpet tiles are driving me mad
Clue 1:
A rat hole on the left, a rat hole on the right, tiles with lines on.......hmmm?
Clue 2:
Similar to above but the stones have lines on.......hmmm?
ive moved the carpet tiles so the 'rat' follows the lines and now appears in the room with the staircase. ive taken the tiles off thye wall and shoved them under the stars but presumably you have to manover them into a pattern of some kind to open the door.
Yep.
think ive put them in the wrong slots how the firk do you get them out again?
ok how do i get the disk out of the friggin box? on lev 2? ( Nismo you are a git :D :D -HOW addictive is this???)
with a pin from the commodore poster
Not sure if you can put them in wrong. Takes quite a bit of jiggling though.
(and the rat ;) )
grrrrrrrrrrrrrrrrrrrrrrrrrrrrr! gettin pissed off
Get to the 'smiley' buttons.....................please!!!!
