electrics help - indicators and full beams
decided to take the dash out today to try and quieten some of the rattles that nissan left me with, thought it was going too well.....
everything was going fine but somewhere along the lines my indicators and full beams arent working! - the full beam flash is fine so to is the hazzard switch, a bit puzzled as to what has happened, have checked the fuses and they seem to be ok and now have run out of daylight!! anybody got any suggestions???
darren
Probably a daft sugestion, but have you checked the connecting block that fits into your stalk switch?
Worth a thought :D
dont think ive disconnected anything from the steering column!! would that be consistant with the full beam flash working though??
its actually just the indicators, full beams do work (had forgotten that normal lights needed to be on first)
it's very tricky to say, I've had mine apart this weekend as well, in fact most of it still is :D And I have niticed that the indicators dont work if the hazard switch is disconnected, like mine is at the mo. Wasnt sure about the other way round though. All i can say is that you may have dislodged somthing, but then that seems obvious :slap: sorry.
yeah - actually redid search for flasher and found the same problem about the hazzard box and have rechecked that, have checked all the other connections but then its got too dark, the alarm is still functioning ok and the indicators flash as normal when i lock it so its not to do with that, so dunno cheers anyway
