No my car is always in the same place where I leave it last regardless whether it is a warm day or cold day. ;)
When does it misfire? Can you give more detail
it just started to miss after id been out in it for a bout 30 mins its missing when its ticking over but fine when i rev it up
Mine had similar mis fire...then started cutting out when warm......i messed about with it for a week....had a situation when it wouldnt fire at all...i left it for 2 days...turned the key and away it went ..started no problem. I bought a new PTU from Courtesy in USA and so far all has been fine.....smoother tickover and even better fuel consumption.
HTH John Crisp
My girlfriends pulsar does exactly the same, doesnt really affect things but its annoying. Recently changed the fuel filter which didnt help so im thinking new plugs and leads.
First go over the car and take off all the connections you can get to and give them a clean.
PTU, CAS, Water temp, MAS etc. It may be some thing as simple as that
