auto question
my auto box revs out in first before it changes to second
it will only change to second if you ease off slightly
my other auto didnt do this.
is it normal (new gearbox 1000 miles ago)
steve
  • Replies 29
  • Views 1.2k
Mine did this, i had a new gearbox ECU thingy, that sortred it.
All the best
Rich :D
whats a gearbox ecu thingy
steve
It could allso be a TPS problem,i read some where that it can effect change up if not set right :confused: :)
does this mean a new tps?
will a gear box test show a fault or not?
the gearbox place say the gearbox is working fine
steve
Spot on.
my old tps was shonked and it did make the auto box change up at very high revs. New tps, problem sorted.
Deffo worth a try
i tried a different tps today
it was a used one not brand new
but it still revs out
steve
did you set it up properly? It shows you in the online manual the voltages it should be reading at closed/wide open throttle, check these.
thanks mate ill look at that this weekend
ive printed it off it looks quite easy
steve
Has anyone checked the oil level in the gear box???
If low can cause problems, plus might need changing.
its had a new gearbox
it did it from the day i picked it up
steve
Its not oil, its a control problem, ie, its being told to do what its doing. More than that I have not a clue. Others have added above on the same idea.
thanks for all your help guys
steve
Just a thought, I was told the Jap and UK autos have different ECUs - is your new box the sam eas the old box?
its a rebuild box
steve
what exactly does the tps do
layman terms please
thanks
steve
layman terms please
thanks
steve
*edit*
Im a dick......... :rolleyes:
a what
steve
sorry steve, i didn't read the question properbly, therefore i called myself a dick.
I think the stella is still in my head.
Sorry again
Rich :)
no worries mate
steve
TPS is the throttle position sensor, measures the angle of the throttle butterflies and sends out a voltage to the ECU/autobox ECU.
if its sending out correct vaulage does that mean its ok
or could it still be faulty intermediatly ?
thanks
steve
If you are sure the tps is ok try doing an auto diagnostic, chances are it will be the revolution sensor, seen it before causing that problem. bolts on outside of box so easy (ish) job
J3ff TT
hi jeff
you did an auto diagnostic for me last month
all was ok then
its been doing it ever since i had car
thats why i think the old gearbox blew up
does the tps position have to be spot on
thanks
steve
