Help Quick Please - Under the Zed now!
Hello,
Spending my Fri arvo under the Zed, just to check.. the diff oil filler is on the RHS of the diff, looking from the back of the car, and is only about 2 inches above the drain plug on the LHS?
Cheers,
Matt.
I remember it being a pain to fill with the squeezy bottle - not much room - also check your connections to the diff oil cooler because that was where my diff oil was going. The leccy pump comes on at high speed high oil temp and part pumps it out if any connections are loose.
Cheers guys! Found it in the end.Job went OK. Needed 1/2 litre approx. Only bad thing was when one of the diff fluid bottles exploded as I squeezed it in! Messy and very gloopy, lucikly missed my brake discs.
Connections to oil cooler OK, definately a leak from the front seal :-(
In on Monday to be fixed anyway!
Cheeeerz.
