headlight bulb
Just been to st helens nissan for a headlight bulb for the wifes fairlady there asking £26 for one bulb.fork that went to halfords got two bulb for £16 and just put a new earth onto it ,how easy is that .
£26 for a forking bulb
wez :duffer:
don't suppose they're any brighter eh?
It looks brighter but that could all be the mind?
Is it still a 55w bulb?
Somewhere on this forum is a mod to upgrade
the h'lights, same as you've done with the extra wire.
Now you can fit 100w bulbs as they are readily available in
the uk.
Have done this to mine, but 100w seem a bit to much,
starts affecting the tickover (uses too much power),
gonna order some 80w bulbs instead.
Hi Sideshowbob
If you have done the H3 conversion, the best bet is to fit either PIAA platinum white bulbs (£38-ish from Demon Tweeks) or log onto
http://www.autostylin.co.uk and buy either Osram or Phillips + 30% 55 watt jobbies (only £14 inc P&P) While you're there order Osram +50% H1s for your main beam....they're dead good :bow:
All the above give the light of 80watt bulbs from only 55 watts.
I had PIAAs and fitted Osrams just to try them - they were just as good so I left them in, plus they are way cheaper..... ;)
Richard :smw:
yes still got the 55w all weather ones they look a bit brighter ?
Been told that you can't get 80w H3 bulbs! :confused:
Some guy in the local motorist shop says you can modify
H1 bulbs to fit & they are available in 80w.
Will probably opt for the phillips/osram jobbies though!
Cheerz Richard Smith :bow:
H1 bulbs to fit .......
I'd love to see that done, because that'd be an amazing job :D
opssss, forgot to write on the pics, :nelson: , H3c's on the left (but metal still the same as H3's) and H1's on the right.
Dave
As a matter of interest, if any wants a pair of H3c's bulbs, used, you can have these two, FOC. Let me know and I'll post them to you.
Dave
bout time someone shed some light on this subject! :dance:
or log onto http://www.autostylin.co.uk and buy either Osram or Phillips + 30% 55 watt jobbies (only £14 inc P&P) While you're there order Osram +50% H1s for your main beam....they're dead good :bow:
Richard :smw:
This place does these bulbs for the same price, but they chuck in a free set of Phillips Bluevision sidelight bulbs with every order!! :cool:
http://www.powerbulbs.com/products/product.php?prodid=pp&type=H3
Useful to know......
I've just added this to my "favourites" list :cool:
Richard ;)
Dave
Are these still up for grabs? :)
Would like to have brighter headlights.From scratch, what is the easiest and less complicated way of doing so ------to an UNMODIFIED jap 1990------Anyone?????
Chas
