remote starting from engine bay
Hi,
Just wondering if anyone knows an easy way of wiring up a remote engine starter inside the engine bay. I would still want the key in the ignition, in the 3rd position. I just want to be able to start the engine without bothering to move from the engine bay.
Vijay
just hook up a wire from the battery to a button then to the small connector on the starter! easy
Hi Mathew,
But it there an easy place to short in the engine bay?
Vijay
yep, that's the sort of thing I want to do but I have no idea where to connect it (looking for easy wires in the engine bay).
Vijay
i wouldn't have thought there is an easy way
apart from via the starter motor m8 as mtl said
and if it's a diy job, your gonna have to be careful, it doesn't short out
while your working under there, would make picking your nose in future
a pain with shortened fingers lol
Thats what I'm in the process of doing, only using a remote start kit, and new alarm , also incorporating my shaved door handle kit as well. using one remote fob, SO as soon as I get it sorted I'[ll let you know the best way to do it.
Easy! Look beside the HICAS control solenoids and there's a connector with a single wire going through it. This is the starter wire - put 12v on the wire and hey presto..... :D
I'll try and find a link ;)
Cheers Andy. Do you know if it would be OK to hook up a wire permanantly? Would I do any damge by putting 12v both ways down the connector?
Vijay
Vijay , if you do this, remember not to be in gear when starting!
Ouch! :mac1:
Anyone??
Vijay
