electrical help!!
got a fault with the electrics!seen a thread by some1else and they had the same problem.basically interior light went out,digital clock fazed out,the door open light stays on and a whining noise from the drivers door occasionally.been told its the relay for the lght/door and couid do with the exact location and where the relay switch is available!well done for this site great help but couid do with aservice manual instead of being a pain in the a*se. :)
hi jonce here again. sorted my problem. it was a fuse gone causing all the leccy problems.
[sIGPIC][/sIGPIC]
hi jonce ,no it sounds daft what fuse is it!!!as the fusebox at the front right hand side of the car has no info for the interior electrics where am ilookin for this fuse 2
Greg buddy. If you look in the drivers footwell,in the bottom right hand corner you will find all the interior fuses. Is it a jap import. If so there is a fusebox translation on 300zx.org.uk enter search and put fusebox. If its the same fuse that went as mine it was the bottom right(furthest away) 10amp.
hope that helps. Nothing worse than leccy probs :mad:
[sIGPIC][/sIGPIC]
nice one jonce,and all you guys gona go on a jap language course might need it ;)
number 54. egg foo yung, thats all i know!! :hyper:
[sIGPIC][/sIGPIC]
sorry greg its the bottom left of the fuse box if you look at it straight on. Ain't i a :xxx: if i dont even know my left from right!!!
[sIGPIC][/sIGPIC]
ahh your not a :xxx: mate got the foo yung translation and worked it out as the fusebox is in a stupid place i changed all the fuses at once!!got it sorted though m8 ,bloody japs i know there short but to get under that cockpit well say no more!! :rofl:
glad your ride is 'Z'OOOOMIN' again buddy :hyper:
[sIGPIC][/sIGPIC]
